tachometer problem
Old Feb 7, 2008 | 04:44 AM
J_Dubb44's Avatar
Car: 1984 Pontiac Trans Am
tachometer problem
I just bought an 84 trans am and the tachometer doesn't go past 1000 rpm. Any idea how to fix that? Or should i just replace the entire gauge cluster?
Old Feb 7, 2008 | 08:41 AM
Re: tachometer problem
Does it seem to act normal below 1000 RPM, like at idle, and then go only that far and stop, like it hits something?
If so, it's probably a metal shaving down in the meter movement. Looking at it under a magnifying glass or with a loupe, you can use a sewing needle to get it out. Just be careful not to damage the hairsprings.
Otherwise, probably easiest to just get another cluster.
Old Feb 7, 2008 | 08:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm unsure about TA's, but in a Camaro you could simply swap out the tach for another (without resorting to removing the cluster at all). Assuming the the tach itself is the problem.
JamesC
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
