Power Steering Pump
Old Feb 9, 2008 | 09:04 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Power Steering Pump
I need a power steering pump for my 86 TPI engine that is V-Belt. Would one from a 6 cylinder work or does it have to be from a v8? Also would one from a serpentine set up work if I just changed the pulley?
Old Feb 10, 2008 | 06:34 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Power Steering Pump
Anyone?
Old Feb 10, 2008 | 07:43 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
I will have a pump and pulley for sale very soon or you could just go out and by one new. If you have a pull apart near you that would be a good option to. I don't know for sure if the V6 one's are the same.
Old Feb 11, 2008 | 05:53 PM
danandamy's Avatar
Car: 86 Camaro
The V6 has a slightly different angled return line fitting on the back of the reservoir. I'm not sure if the pressure line fitting is the same size or not. To make a long story short, it's a different part number for the v6 vs the v8.
Glowsock
Jul 24, 2025 03:15 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
86White_T/A305
Aug 17, 2015 12:16 AM
