why is my car missing?please help
Old Feb 10, 2008 | 10:12 PM
kellyfoxman's Avatar
i have a 1988 gta 350 tpi,last week it started missing then it just quit.now it started again and wont stop,check engine light comes on when started most of the time,injectors ohmed out good,any help?thanks
Last edited by kellyfoxman; Feb 10, 2008 at 10:13 PM. Reason: Automerged Doublepost
Old Feb 10, 2008 | 10:36 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: why is my car missing?please help
because someone took it? j/k man, do a good tune up on it ,cap,rotor,plugs wires. when was the fuel filter changed? later jimmy
Old Feb 10, 2008 | 11:22 PM
i put a fuel filter on yesterday,if it was a wire or plug why would it stop doing it,i took the cap off it looked fine.
Old Feb 10, 2008 | 11:31 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
if cap looks good then check the wires good, could have a burnt spot on one,check it for cracks.plugs will sometimes not fire if theyre old or carbonrd up, or fowled from oil deposits.hth,jimmy
Old Feb 11, 2008 | 06:30 PM
Shred's Avatar
Car: 1986 Iroc-Z
Engine: 350cid crate
Transmission: t5- 5speed
Axle/Gears: stock
ya I kinda got a similar problem, though my iroc has a 350 with an eldelbrock carb and manifold. The idle timing is at 10 degrees. If the engine is cold it will miss quite bad, but when its nice and hot, the miss is barely noticeable if there at all. Its strange because its only bad when its cold. does anyone have suggestions? would a vacuum leak do this, or possibly a carb problem?????
please help!
hectre13
Dec 11, 2023 08:14 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
MY87LT
Aug 17, 2015 08:43 AM
Exxon Limited
Aug 9, 2015 08:13 PM
