need help setting the base timming
Old Feb 10, 2008 | 10:13 PM
jstuart83's Avatar
hey guys i need some help setting the timming on my 87 gta transam the guage on the block that is suppose to show you the degrees of timming is un readable, from the big indention on the guage which i suppose is suppose to be o degrees what are the increments for each notch or do you go by where the saw tooth looking part is pointing to, and also when i disconnect the advance connector the engine dies i can keep it running by throttleing it up to about 1200 rpm but i shouldn't have to do this right? any help would be great thanks
Old Feb 10, 2008 | 10:32 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: need help setting the base timming
should be set at 6* each mark is 2* are you unhooking the brown wire with black line around it ifso it shouldnt cut off,later jimmy
Old Feb 10, 2008 | 10:39 PM
jstuart83's Avatar
yea im un hooking that wire i i think the timming is really bad off thats why its cutting off but where is the o degree mark on the guage i need to know this so i can tell where the timming is set now thanks for your reply
Old Feb 10, 2008 | 10:49 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
oh sorry dude, the 0*is going to be the longest mark on the scale, usually in the middle.,jimmy
Old Feb 11, 2008 | 12:04 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
my 0* mark is on the driver side of the scale (if im wrong dont kill me) but i know my 0* is at either end of the scale, is yours just dirty or something? if it is just get a coat hanger or something long and put a rag on the end, spray your gauge with some brake cleaner and wipe it off
Old Feb 11, 2008 | 03:50 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Here is a pic from my Camaro, its on 6 degrees.
(Oooh yes, I took the picture when the engine was running and I´ll checked the ignition timing :-) )
Old Feb 11, 2008 | 06:25 AM
jstuart83's Avatar
thanks man this is exactly what i needed to see also thanks to everybody else all the input was helpful ill buy you all a round of virtual shots thanks guys
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
Vintageracer
Jan 10, 2020 05:33 PM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
TheExaminer
Aug 19, 2015 10:07 PM
