Ignition Key question
Old Feb 10, 2008 | 11:09 PM
Speedfreek's Avatar
OK I have a 90 Firebird. I have lost the key and can't get any lock smith to want to come out and fix the dang thing. It is VATS system can I just change out the ingnition cyld or will it have to be the same vats key to work?
Old Feb 10, 2008 | 11:37 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: Ignition Key question
take your registration card to any gm dealer they can take the vin number and cut a new key for you,later jimmy
Old Feb 11, 2008 | 06:38 AM
jstuart83's Avatar
jimmys right but to answer your question if you replace the cylinder you will have to still know what rististor was on the key there are 9 different ones i believe then you would have to cut a new key with the right resistor value in order for it to work. i use to make these keys at a hardware store where i use to work it will problity coust you about 20 bucks at a hardware store i don't know what the dealer will charge, maby nothing if you catch them on a good day
Old Feb 11, 2008 | 06:43 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
FBODY had 15 different resistors
Old Feb 11, 2008 | 09:56 AM
Speedfreek's Avatar
Already done that. They told me it would tell them how to cut the key but not which vats key it needed. They made me a set of keys with out the chip in it and they open the doors and turn the ignition but without the vats key it wont start.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
