Belt tension bolt
Car: 1989 Camaro
Engine: 2.8L
Belt tension bolt
I have an 89 camaro with a 305 and I was changing the belt and the bolt head snapped off of the bolt tensioner thing so now the rest of the bolt is stuck and The tensioner can almost slide off does anyone have any ideas on how to fix this or how to get the bolt out? thanx
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
Re: Belt tension bolt
pull whatever the bolt is in off then use vice grips and remove or drill a small hole in the bolt and use a device called an easy out is is a cone shaped thing with reverse threads on the outside of it so when you go lefty loosy into the hole you put in the bolt it grabs and loosens the bolt, at least that is what they are suppose to do usually isn't that easy.make sure you don't damage the threads when you are drilling the bolt.
Car: 1986 IROC-Z
Engine: '69 camaro 350/350hp
Axle/Gears: Posi 3.23
and if you have to go buy one, go to parts store not walmart. You will get what you pay for.
If this is the bolt that holds the pulley on, the best thing to do might be to just replace the whole tensioner assembly. Not too expensive; maybe $50 or so.
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i would start spraying the threads with pb blaster or another penetrating lubricant. then go with the easy out.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
