Need opinions on my stroker build.
Old Feb 15, 2008 | 03:56 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Hey guys,
I have been saving up to build my engine for a while now. I just completed the shortblock (for the most part) and now I am about to buy a set of heads.
I was looking on craigslist and found a set of UNUSED Edelbrock Vic Jr heads.
Specs of shortblock:
'85 350 Block decked and bored .060" over.
Hypertectonic coated pistons.
5.7" stock connecting rods.
400cu in Cast steel crankshaft.
mellings double roller timing chain.
Comp Cams Duration 284/305, Lift .507/.525 (nitrous cam)
Stock oil pump and pan.
Everything is balanced.
I called the guy about the heads and he bought them from a friend who got into a car accident and never used them, then he never used them because he ended up going to a BBC. The heads have stud girdles and he wasnt sure if they have been ported, but according to him they "look shiney on the insides like they've been polished." he also said the only number he saw at the time was 7763.
Anyone want to give me opinions or feedback? Im debating wether or not to buy the heads.
Rest of the car:
1988 Formula
700R4 Automatic.
Built 10 bolt 4.11 gears
Spohn SFCs Spohn LCAs LCARBs Spohn Tq Arm and crossmember.
Old Feb 15, 2008 | 04:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Need opinions on my stroker build.
I think those might be a little big for you, depending what you're looking for. They're 70cc chambers, 215cc intake with raised exhaust ports.
Old Feb 15, 2008 | 04:48 PM
Engine: 388 Carb
Axle/Gears: 4.10
The 70cc chamber is what I want to keep my compression ratio down a little bit, but why do you think the 215cc runners are too much? Ive heard alot of people using these on a 350 with good results, I thought with a 388 they would be even better???
I am looking for a high horse power motor that will be able to be "streetable"
Old Feb 15, 2008 | 04:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
For a streetable motor, you want to keep the port sizes smaller to keep the charge velocity up.
Old Feb 15, 2008 | 05:17 PM
ljnowell's Avatar
On a 383, i think you may be ok with that. A 350, no way. kinda depends on what you want to do with it to.
Old Feb 15, 2008 | 05:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Those heads would like more cam, though, and making as much power as they're capable of should really have something better than stock rods.
Old Feb 15, 2008 | 05:51 PM
Engine: 388 Carb
Axle/Gears: 4.10
How much more cam can be used and also keep it idleing on the street im already with Duration 284/305, Lift .507/.525... I think these heads for $800 is a good price that is the only reason I am leaning towards them...
Oh, my carb is a 750cfm Barry Grant Speed Demon
Old Feb 17, 2008 | 10:51 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Go to Stan Weiss
World Wide Enterprises.
He has all kinds of calculators and comparison charts for Head flow vs rpm vs hp, injector flows ect. just look up your numbers and learn something new.
From His ( COPYRIGHT © 1997-2008 World Wide Enterprises ) tables
Edelbrock #77569, #77579, #77589, #77599, #77619, #77629, #77639, #77649 Victor Jr. 23 Deg. Alum215/85 2.080/1.600 64/70 67/64
95.5% 119/112
94.1% 177/153
86.4%
52.1/76.1
154/225
.618/.695
364 hp 226/188
83.2%
66.5/93.5
197/277
.592/.640
465
504 hp 265/207
78.1%
78.0/103
231/305
.556/.564
545
591 hp 281/217
77.2%
82.7/108
245/320
.491/.493
578
627
705 hp 285/220
77.2%
83.9/109
249/324
.427/.428
Est HP and Avg flow cfm
586
636
715 hp---226/183
81.1%
1.33/2.59
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
Jlanz55
Sep 29, 2015 08:55 AM
JSDaddy189
Sep 26, 2015 03:50 PM
