need a lil help upgrade to speed density
Old Feb 15, 2008 | 07:09 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
if i buy a new harness and ecm to upgrade to speed density for my 85 tpi, will the body connector still work with the ecm? who has upgrade from 85 to 92?
Old Feb 15, 2008 | 07:40 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: need a lil help upgrade to speed density
I think there is a tech article somewhere on the site, to re-pin your current harness to use a speed density computer...... That would certainly be easier..
Old Feb 15, 2008 | 07:57 PM
jayk2k3's Avatar
Car: 85 camaro z28
i dont want to repin, alitlle to confusing
Old Feb 15, 2008 | 08:13 PM
ploegi's Avatar
Engine: 5.7 TPI
A lot easier than replacing a wiring harness.... I think there are less than a dozen wires that need to be moved...... Have a look here, before you decide.
Old Feb 16, 2008 | 01:02 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, the body connector is different as an '85 has a separate engine harness and car harness. A 89+ car has the engine and car harness together in the same loom.
Old Feb 16, 2008 | 07:44 AM
ploegi's Avatar
Engine: 5.7 TPI
DOH! Missed that it was an 85...... Harness swap is in the future.......
Old Feb 16, 2008 | 02:02 PM
jayk2k3's Avatar
Car: 85 camaro z28
wat about a 86 harness. repinning is not my thing. this realy sucks
J-money
Jan 4, 2019 09:45 AM
tonys91rs
Oct 10, 2015 03:31 PM
383cam
Sep 9, 2015 06:01 AM
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
