stupid smog pump
Old Feb 15, 2008 | 09:29 PM
outlaw85t/a's Avatar
stupid smog pump
how do i take the emissions of my car and will i gain any power from it
Old Feb 15, 2008 | 09:52 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: stupid smog pump
rmeoving any of the equipment will not noticeably increase power and there really is no need to remove any
save yourself unneeded work
these vehicles are emssions tuned, lean jetted carbs, computer controlled timing and injection, and so on
and the AIR(smog) system has no effect on performance at all it simply injects fresh air into the exh manifolds to completely burn fuel that didnt burn completely inside the chambers, there is no reason at all to remove this unless it is so far damaged that it cnd that it cannot be repaired
removing it will not increase your power whatsoever
modifying in order to increase fuel and air into the engine is how to increase power in an internal combustion engine
chip burning
higher fuel delivery
ported intakes
larger valves and camshaft
larger exhaust as well
higher RPM(higher stall covnerter, deeper axle and trans ratios
and so on
Old Feb 15, 2008 | 10:06 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I agree, the only power loss from air injection is the effort it takes to turn the pump. And if you've ever turned one by hand, you'll know that it's very easy to turn. Oh and maybe 5 or so pounds of extra weight.
Old Feb 15, 2008 | 11:01 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
Ditto
Old Feb 16, 2008 | 08:26 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
The biggest reason that people remove emissions equipment (besides those that mistakenly believe that 20 HP will magically appear in it's place) is for aesthetic reasons. An uncluttered engine compartment that looks more like "race" than "stock" and makes working on the engine easier. As far as the difference in HP between an idler and an air pump that has the piping removed, there is none.
The catalytic converter is another story. It's part of the restrictive factory exhaust and is the first thing that should be changed.
If you're out to reduce the accessory load and your car has electric fans, you can free up 4-5 HP by "sleeping" the alternator at WOT, turning it into an idler only at WOT. That's only a $4 switch and some wiring.
Cleotiz
Jan 6, 2018 08:56 PM
italiano67
Dec 11, 2016 09:21 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
