ticking noise
ticking noise
when i turn the key on in my 86 iroc z28(not start) i hear this whirring clicking pulling noise in the paassenger side area of the engine closest to the windshield. I think it has to do with some kind of cooling part. When i turn the ac on it just gets worse. Anyone know what this could be. Ps the tempeture control lever doesnt move it is stuck for some reason anyone know a fix?
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
Re: ticking noise
Also does it make the sound when its running with out the ac/heat on?
Its an easy fix I did it in 20 mins, all you have to do is take off 8 bolts, the ground wire and some other wire, and a little rubber tube, you pull it out and there should be a fan like thing on the end of it swap that over to the new blower motor and put it in.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: ticking noise
blower motors are dirt cheap about 20 bucks
a good used one would be fine they rarely fail
almost any car or trucks one from the 70s on up is the same
caddy , olds, pontiac, chevy, buick, gmc, etc
it could evne be sticks in the blower fan blades, remove the blower and clean the box out
i always pull good working ones from carsi junk and trucks too, all the same virtually
a/c ones anyways
in which have a wider fan blade set than a/c delete vehicles
in which are only about 2" or 2.5" wide blade set
good luck
a/c ones anyways
good luck
Car: 1998 Mustang
Engine: 3.8L V6
Re: ticking noise
i took the blower motor out was a real b with the fender walls blocking me from getting the 2 screws at the bottom. since my car is ac right i would need a blower motor with the ac option correct?
can someone maybe point me to a site such as advanceauto and the correct part number or the blower motor for me i was looking and i wasnt sure one what i needed. do i need the blower motor itself or that and the white airfilter looking thing that goes around it.
Transmission: 4L80E/4L80E
www.partsamerica.com
Select Advance Auto as the store. Fill in your vehicle information, pick the one for AC application.
Car: 1998 Mustang
Engine: 3.8L V6
Re: ticking noise
You don't need the wheel unless yours is broken, so if its not get the one without the wheel and put your old one on it, its just 1 bolt holding it on.
Re: ticking noise
sjorgens
Oct 1, 2015 07:54 PM
david068513
Sep 13, 2015 11:24 AM
