Timing Cover Walking Around w/ New Roller Cam???
Old Feb 17, 2008 | 10:50 PM
drb930's Avatar
Car: 1987 Chevy El Camino
Engine: 357 CID w/Lingerfelter Super Ram
Transmission: 700-R4
Axle/Gears: GN 8.5 342's
Hi,
Before i open up a brand new engine-
Does anybody know why my timing cover is pulsating while at cranking speed on my small block?
I just converted it to a LPE Roller Cam.
Is the timing cover different for the roller cam motors?
I know the end of the roller cam is longer, and the double roller cam gear that i put on brings the chain back into alignment with the crank gear.
Thanks in advance,
Dave
Old Feb 18, 2008 | 07:25 AM
Re: Timing Cover Walking Around w/ New Roller Cam???
What block? EXACTLY what parts are these? (cam, timing gear, any spacers or washers or whatever) Tell us EXACTLY what you have.
Old Feb 18, 2008 | 08:58 AM
drb930's Avatar
It's a 2 piece rear main block.
Has a LPE 219 factory roller replacement cam.
Double roller chain set for the factory roller cam setup with the factory thrust plate behind the cam.
The cam has the nose piece for the factory thrust plate, and the timing gear set has the proper offset for the cam, i had to change out the timing gear set from the other non-roller cam.
Old Feb 18, 2008 | 09:02 AM
How far does the dowel pin in the nose of the cam stick through?
Alot of the LPE cams come with the late-mdoel (long) LT1 pin, which IIRC has to be cut off with a die grinder ro something to fit the L98 style setup. You can't even knock it back into the gear far eoungh because it will hit the retainer plate before it's far enough back.
Old Feb 18, 2008 | 09:06 AM
drb930's Avatar
Here is the link with pictures as to how i held the thrust plate.
https://www.thirdgen.org/forums/tech...-accept-3.html
Old Feb 18, 2008 | 09:17 AM
drb930's Avatar
I dont really remember, and dont have any pictures, but i believe the dowel pin was flush at the front of the cam gear.
That will be something to take a look at when i take the timing cover off.
I have the 1 piece oil pan gasket, so i guess i have to loosen up the whole oil pan.
Old Feb 23, 2008 | 11:41 PM
drb930's Avatar
Sofakindom,
You were right on the money, it was the dowel pin that was hitting the stamped steel cover.
Probably if i had had an alum cover it would have been fine.
I ended up snapping the dowel pic trying to get the cam gear off, so that fixed that.
Still has a 1/4 inch left.
Thanks again for the help,
Dave
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
