3rd oil pan gasket third leak??????????
Old Feb 18, 2008 | 01:58 AM
fychelio's Avatar
Car: 1983 pontiac Trans am ws6
Axle/Gears: ????
okay so i got a new oil pan and gasket and this time even put a dab of silicon in the corners and now im leaking again from that spot in the front lip of the gasket inthe dead center... but i saw an oil build up befor i had even put oil in the car?????? like after the bolts for the pan were torqued their was oil in the front lip.. could it be the timing cover chain seeing as in its only a one drop kinda leak? or main seal?
Old Feb 19, 2008 | 09:44 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: 3rd oil pan gasket third leak??????????
See if you can follow the oil trail. It could be your timing cover or still your oil pan gasket. I use silicone on both sides of the gasket in the front and rear corners of the pan.
Old Feb 19, 2008 | 06:04 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yes it can very well be the balancer seal
very common issue on SBC engines
wears a deep groove into the balancer snout and leaks there
they have a sleeve repair kit for this very inexpensive at any parts store
i always black TRV seal the entire front oil pan rubber seal
top and bottom of it seal it to the timing cover and to the oil pan both
have to do this almost always to make it not leak
i always do this on my engines i build for ppl or own personally
same with the front and rear intake rubber seals, i dont even use those
they are junk
use rtv black only to seal
Old Feb 20, 2008 | 03:31 AM
fychelio's Avatar
Axle/Gears: ????
lol yea i tossed those out too for the intake front and rear, just used a 1/4 inch bead of rtv on that.. imma change the timeing cover.... actually im not im beat imma take it to the shop in the morning let someone else have some fun.. 3 straight weeks of hell! i deserve it haha... i love driving this car its my first one but man she goes..
Old Feb 20, 2008 | 04:57 PM
chevhedz28's Avatar
Car: '89 formula,'88 Iroc
Engine: 350,305
hey use the one piece rubber gasket with the steel shim and crudh sleeve inserts with silicone at the corners, and change the pcv valve. It souns stupid but if it's clogged or not funtioning properly it will cause the oil pan to leak. I've seen it on older chrysler 383's and seen it on small blocks too.
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
