Compression questions....???
Old Feb 22, 2008 | 03:11 PM
bcacali24's Avatar
Hi im 15 building my first sbc. im wondering if my thoughts about my set up are right. first off its a 350. what kind of compression am i looking at with 58cc heads, felpro head gaskets, stock deck hight, sealed power hypertonic flat top 4 valve reliefs and true 1.560 not 1.540 compression hight, stock rods and stock crank.
will there be and problems that will need to be adressed with this combo?
thank you for any help input or suggestions.
Old Feb 22, 2008 | 05:09 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Compression questions....???
perfect age to start building.. i was 15 when i built my first.. well anyways, research more into the parts you want and heres a compression ratio calculator that you can use.. if you are going to use iron heads, stay UNDER 10.5:1.. for aluminum, stay under 11:1.. this is considering you only use 91/92/93 octane.. for 87 octane, minus a full point..
http://www.kb-silvolite.com/calc.php?action=comp
dont worry too much about the dynamic ratio unless you are reaching the limit on compression.. thats where cam duration comes into play.. any other ???'s, ask..
Old Feb 22, 2008 | 05:28 PM
bcacali24's Avatar
also i want to use my original 76cc heads but i want to get around 9.5:1 compression out of the motor and i am wondering how i do that with those large chamber heads
Old Feb 22, 2008 | 06:24 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
dome pistons....but if you can score some 58 or 64cc heads relatively cheap, i'd go that route and then you can run plain 'ole flat top pistons and easily reach your compression goals
Old Feb 22, 2008 | 06:33 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
If you haven't bought the pistons yet, you could put a 383 crank in it and get 9.2:1 C/R with the 76cc heads, .020 deck height .040 gasket, using -5cc flat tops pistons.
Otherwise you would have to use a dome piston (everyone hates them but me) to get a decent C/R with the 76cc heads on a 350...
Old Feb 22, 2008 | 07:05 PM
dome pistons usually don't have a large following because of the piston-valve clearance issues with them if you're not spot on in your measurements....ever had a piston smack a valve @ 6000rpms?
Old Feb 22, 2008 | 07:22 PM
Engine: 350 4BBL
Actually the ones I've used had a slot that was much deeper than the "eyebrows" in flat-tops.
Everyone I know says that they are "old-school" and worry about "flame propogation" across the combustion chamber thinking that a flat-top gives a much better "open" combustion chamber. But there is a whole lot more going on in the combustion process than meets the eye...
Look at motorcycle engines (or any high output-per-cc engine)
They ain't flat tops...
Old Feb 22, 2008 | 07:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Perhaps, but where are the valves?
There are 76cc SBC heads, and there are 76cc doorstops - which do you have? Casting #'s will tell the tale.
Old Feb 23, 2008 | 11:16 AM
bcacali24's Avatar
casting number on the heads are 333882
Old Feb 23, 2008 | 11:52 AM
Engine: 350 4BBL
Sofa commenting on 882 heads in this THREAD:
Not worth it. Wouldn't be worth it, even if they were FREE, and even if somebody else did all the work and paid all the misc expenses like gaskets and such to put them in your car. No matter what heads you have now, that casting is worse. Even if you have TBI swirlies. They're SURE not worth putting labor and machine work money into.
That's one of the worst, most anti-performance castings there is.
I've PAID people to come haul piles of that kind of crap off my property.
Catch me sometime when I'm not in such a good mood and I'll tell you what I REALLY think of them.
He was actually being kinda mellow about it ...
They will however, run slightly better than an engine without heads.
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
