so why would....
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
so why would....
my car deisel when i turn the key off. i just reinstalled my intake manifold and now my engine deisels really bad after shutting it off. once in a while it will shut off fine but thats rare. i did install a hei dist thats vac advance along with the intake might that have something to do with it?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: so why would....
what is your timing at?
it's either retarded timing or too high an idle speed.
Car: 87 trans am
Engine: 5.7
Transmission: t-5
it idles at just about 700 in gear 1000 in park or neutral. and just to make sure turnin the dist clockwise is retarding and counterclockwise is advancing right?
Car: 85 Camaro
Axle/Gears: 3.42 posi
Car: 1984 Z28
definitely use a timing light to set the timing, not by ear or any other means.
Car: 87 trans am
Engine: 5.7
Transmission: t-5
so i adjusted my timing got rid of the spark knock and got the engine running smoother but the deiseling was still there. so i took a look at my idle again noticed it had gone up to a bit over 1500 in park or neutral and was around 1000 in gear. i turned it down way down. it idles at about 700 in p/n and just above 5 in gear now. runs like a dream and stops without problem when i cut it off. looks like it was both timing and to high an idle
