L98 Rebuilding Books
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
Car: 87 GTA
Engine: Under Construction
Axle/Gears: 3.70:1
Re: L98 Rebuilding Books
don't waste your time or $ with those books.. The books I learned the most on were "How To Build Max Performance Chevy Small Blocks On A Budget"
http://store.summitracing.com/partde...5&autoview=sku
"How to build big inch small blocks"
"High Performance Chevy Small Block Cams and Valvetrains"
All the other little stuff you can search the board for free and get correct answers. If you are looking to make some good hp #s then get rid of the T.P.I. intake and go with a HSR, Miniram, or an LT-1 style.
Transmission: 4L80E/4L80E
I must admit that's the first time I've heard anyone bad-mouth Lingenfelter's book.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
... and the first time I've heard "forget books, read the board!".
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Not everyone is looking for max HP and low ET's
John's book $10 amazon.com
old books old cars stuff don't change alot for DD.
They don't only tell you just how to get every last HP out of the engine in books like that - they teach you how everything works, and works together, to get to the desired end result. Books like that teach you how to create an engine combo for yourself with parts that compliment each other, and not work against each other. Books like that are a great idea for someone still learning - I still use them from time to time too.
block, book, books, boos, buiding, build, engine, gen, l98, maximum, maxperformance, performance, rebiulding, rebuild, rebuilding
