Rocker Arms??
Old Mar 3, 2008 | 03:54 PM
pyrofire127's Avatar
Rocker Arms??
So im thinking about switching out my rocker arms to a 1.6? but i have no idea how hard they are to switch. me being new to domestics i have never switched rocker arms out before. also does anyone have an idea of what brand tends to be better for this?
Old Mar 3, 2008 | 05:05 PM
400 hp's Avatar
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
Re: Rocker Arms??
its not to hard to do you just need the pre load set right. make sure your motor dont have a worn timing chain.. as for rockers run a name bran comp cams crane...
Old Mar 3, 2008 | 09:57 PM
Re: Rocker Arms??
dang i feel dumb now.... whats preload and how do you set it?? as for the timing chain its new, whole engines a rebuild from an 88gm
Old Mar 3, 2008 | 10:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Rocker Arms??
Get yourself a book on chevys.
Preload = lash. You set your valve lash. Look up EOIC on this forum for the lowdown on how to do it.
It's an easy mod
Old Mar 3, 2008 | 10:22 PM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
Re: Rocker Arms??
Almost...
Lash is not the same as preload. Lash is a term used on solid cams which
requires a certain amount of distance between the assembly.
Pre-load is the opposite where the lifter needs to have all of the "lash" taken
up, as well as a preset amount of spring load for correct operation.
Ed1LE
Sep 30, 2018 09:14 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
