Trying to Balance Acceleration with Top-end
Okay, recently purchased a nice third-gen that was previously a drag-car for several years. The set-up is a carbed 350 (vortec heads, edelbrock carb and intake, good headers and exhaust) with a Turbo 350 tranny with a 3.73 rear end ratio. I'm not sure what kind of cam is installed.
Right now you can tell the car is set-up for a quarter mile. At 55 MPH I'm running every bit of 4500RPM (and probably 5 miles per gallon... lol). 75 MPH is about as fast as I'm willing to take the car for any duration, I don't even think I've taken the car over 80 yet. To make a long story short, this car sold almost all of its top-end for acceleration.
My question is, how can I change that without loosing all of my acceleration? I really do enjoy getting up to 70 in a hurry, but this lack of top end speed is killing me. I'd like to be able to take the car to atleast a hundred and ten without fear of blowing the motor.
I've been told that changing my rear-end to something more 'streetable' (ala 3.23) will fix it, but will that kill my acceleration? I've also heard changing to a new cam would allow me to keep my current rear end ratio while getting more top end speed.
What can you guys recommend?
Re: Trying to Balance Acceleration with Top-end
I would leave the gear alone. In fact, that's what I have in my car; just that stock one like yours. Works fine. Worked fine for a LONG time with a T-5 (similar OD to a 700), and works fine now with a T-56, except that it's kind of low. It could really stand to go up to 4.10. But that's just my setup; yours is a bit different, being an auto car.
Since you know what heads, gear, converter, weight, exhaust, and so forth are there, pick a cam that suits YOU and the way YOU want to use the car. Cams are CHEEEEEP, even the very best. Especially compared to the amount of fuel a poorly chosen one can waste, or to your continued frustration trying to overcome a wrong one (no matter how low its purchase price was... those couple of pennies disappear into the overall noise level REAL QUICK), or to other parts you might buy to try to "compensate" somehow for a wrong one.
From your description, I'd suggest a Comp XE262.
I'm not a big fan of those Edelbrock (Carter) carbs, myself. They're "OK", but that's about it. They can be made to run "OK", and get "OK" fuel mileage and decent driveability, and "OK" power; but they are a very poor fit to our cars. The fuel line arrangement is pitiful, the linkage isn't great, etc. You might want to consider replacing that with either a Holley 6210 (650 CFM spreadbore man sec), or a good old Q-Jet.
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
55 mph with a th350 and a 3.73 is no where near 4500rpm. Are you in second gear? Are those gears not 3.73? look around your setup more closely.
That "4500 RPM", was that the factory tach?
Not that it matters too much, except just to get the numbers straight.
As for the Edelbrock Carb, I'm not a terrible fan either. But its working pretty good now, no complaints yet. Would it actually be worthwhile to ditch a working Edelbrock for a new Holley?
The engine and tranny I know, but I'm not sure about the converter in my car. Perhaps my mechanic will be able to figure out which variety I have in it.
Nope, after market. My mechanic told me its a fairly high dollar tach. But that doesn't necessarily mean its set right. heh
Is it a significant increase over the Turbo 350?
Torque converter
torque converter lockup clutch
Second question; is the 700-R4 robust enough to support the horsepower my engine produces? I'm looking at 250 right now, and maybe 300 in the future?
I thought the 700-R4 was for less horsepower heavy applications and the TH350 was for more "hardcore" applications?
Well, look at it this way:
The trans behind the LS1, LS6, etc. is the 4L60E. That model is IDENTICAL to the 700, except it has solenoid valves to tell it what gear to be in instead of hydraulic control. Same clutches, same shafts, same gears, same EVERYTHING, as far as power transmission and strength is concerned.
Those cars put more power than that little bit you're talking about TO THE WHEELS, off the showroom floor. And then people mod them and get even more. And the trans still holds up fine.
Eh? Does it sound like enough?
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
monte87cortez
Sep 26, 2015 08:10 PM
