WONT START PLEASE HELP!!!!!!!
Old Mar 5, 2008 | 02:04 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Ok my 90 camaro rs 305tbi wont start. It has new battery new alt. the starter wont even click. what is going on. PLEASE HELP!
Old Mar 7, 2008 | 05:10 AM
Pat Hall's Avatar
Re: WONT START PLEASE HELP!!!!!!!
If you're sure all your wiring/connections are tight and corrosion free, my next guess would be the VATS system. When you turn the key on, there's a "security" light in the instrument panel down by the "check engine" light. If the security light is blinking or staying lit up when the key is in the on position, then you have a VATS problem. When VATS is functioning correctly, the security light only lights up for a couple of seconds, then goes off. VERY common problem on 89-up 3rd gens.
Old Mar 7, 2008 | 12:08 PM
Hey thanks alot it was my starter solenoid. It was like 20 bucks then for the hole thing it 60 so i installed it and runs good now. But i have had that problem before with the security light before and the VATS system i have no clue about? If it happens agian what should i look for?
thanks
kevin
Old Jul 10, 2008 | 08:16 PM
jreyes106's Avatar
I'm having the problem with the security light staying on. If it is a common problem do you know the solution to the problem.
Old Jul 11, 2008 | 08:35 AM
i cleaned the ignition out and now it work fine.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
