cant tell what kind of knock
Old Mar 6, 2008 | 09:49 AM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
Hey I just started driving my firebird and I notice this clicking chattering type noise but i can't tell if it is an exhaust leak detonation a valve or a loose rocker. it makes the noise under load certainly can't hear it under the hood. I hear it the loudest in 5th gear because the rpm is the lowest and i have a mechanical fan but it almost sounds the same in a lower gear just harder to hear. this noise is rhythmic meaning it is predictable and not random.
my worst fear is rod knock but i cant hear it at idol so I'm not too worried about that
what do you guys think? any input is appreciated
Old Mar 6, 2008 | 10:57 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do you have headers?
Old Mar 6, 2008 | 02:03 PM
mxcrazed's Avatar
Engine: None
Transmission: none
Re: cant tell what kind of knock
stock cast manifolds
Old Mar 7, 2008 | 12:52 AM
mxcrazed's Avatar
Engine: None
Transmission: none
please.
Old Mar 7, 2008 | 10:28 AM
ljnowell's Avatar
your description could be anything. Its impossible to say, its this, or it isnt that Post a sound clip of the car running with the noise. Is the knock present in all gears? Only under load? While accelerating? Below a certain RPM? A whole lotta more info is needed, and even then it could be anything.
Old Mar 7, 2008 | 01:13 PM
mxcrazed's Avatar
Engine: None
Transmission: none
Like i said it is there all the time, in all gears it is most apparent in 4 and 5 because i can hear over my mechanical fan. I'm gonna go look for carbon around the manifolds. it is hard to get a sound clop when I only hear it while driving it is not very loud but I can try.
Old Mar 7, 2008 | 01:25 PM
five7kid's Avatar
Loose flywheel bolts will make a weird sound.
Any problems with oil pressure?
Old Mar 7, 2008 | 01:35 PM
mxcrazed's Avatar
Engine: None
Transmission: none
I will have to go hook up the oil pressure gauge to inform you of that. I guess I'll go do that. It is mechanical and I just don't like the idea of 60psi of hot oil shooting out at me.
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
bigjay89gta
Oct 15, 2015 08:04 AM
hartsmike
Oct 2, 2015 07:11 AM
efiguy
Sep 27, 2015 01:30 PM
