float bowls need help
Old Mar 6, 2008 | 11:15 PM
ponieburner91's Avatar
i have a edelbrock 600 cfm carb were are the float bowls located how do i acccsess them to clean them
Old Mar 7, 2008 | 08:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: float bowls need help
They are on the sides of the carb. Remove the rod & piston assemblies, disconnect the accel pump rod, remove top cover screws. Carefully lift top cover off. Note that the floats will be attached to the top cover.
You may want to check/set the float levels and the float drop while the lid is off.
RBob.
Old Mar 7, 2008 | 09:58 AM
thanks ill let u no how it went
pjsparts
Oct 29, 2025 06:39 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Springster
Sep 13, 2015 01:38 PM
Formula_88AE
Sep 3, 2015 01:47 PM
