GM Serpentine Conversion Kit
Old Mar 7, 2008 | 09:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following system seems complete: 12497698 - Small Block Chevy Serpentine Accessory Belt Drive System "Deluxe With Air". Any installation hick-ups, or is the installation pretty straightforward? Tips or tricks for the conversion would be welcome.
JamesC
Old Mar 7, 2008 | 12:15 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Re: GM Serpentine Conversion Kit
Hi James, I'm getting to install my serp parts from a '90 RS too. I think that GM kit is almost the same the TPI parts. There are two things you need to be aware of. The first is pretty obvious the A/C and alternator swap sides, so you'll have to run wires and lines. The other is the older blocks don't have the second accessory hole on the passenger side. You have to drill and tap one. I'm keeping my fingers crossed that if I just drill only 1/2" it won't hit the water jacket.
Old Mar 7, 2008 | 12:27 PM
JamesC's Avatar
Hit Summit and type in the above part number. Then look toward the bottom and you'll see a GM installation procedure that appears to be VERY helpful (torque values and p/n's).
JamesC
Old Mar 7, 2008 | 12:34 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Originally Posted by JamesC
Hit Summit and type in the above part number. Then look toward the bottom and you'll see a GM installation procedure that appears to be VERY helpful (along with all p/n's).
JamesC
Good tip
Old Mar 7, 2008 | 12:43 PM
JamesC's Avatar
trumps,
Take note of what the guide says about those holes. Beyond the kit, I'll need the A/C hoses, a bit of wiring for the A/C compressor (GM 12101937), and a smog delete pulley (GM-6167), though not absolutely necessary, I guess.
JamesC
Old Mar 8, 2008 | 02:37 PM
JamesC's Avatar
Apparently the fuel line will require some massaging as well.
JamesC
Old Mar 8, 2008 | 09:51 PM
trumps2000's Avatar
Car: 1985 Z28
Actually the fuel line I purchased from Classic tube clears, but I have of issues. How is the stock line run? Mine passes between the water pump and timing cover.
Old Mar 9, 2008 | 06:28 AM
JamesC's Avatar
Stock placement. I found a member who'd converted his 83. He says that the line wouldn't fit and that he was forced to cut it and run a rubber line. My line was previously cut to accommodate my Holley.
JamesC
Old Mar 9, 2008 | 10:06 AM
JamesC's Avatar
My bad, the kit contains the smog delete pulley (Pulley, idler lower), p/n 10129569. Anybody have an idea of approximately how long the swap will take if I'm prepared with the necessary parts and air tools?
JamesC
Old Mar 9, 2008 | 10:29 AM
trumps2000's Avatar
Car: 1985 Z28
85SS just finished the swap you can ask him in this thread
Old Mar 9, 2008 | 10:36 AM
JamesC's Avatar
Thanks, I may. I saw that link a day or so ago when I was researching--I wanted to know that the kit was pretty much a bolt-up (and that no drilling/tapping would be necesssary). Pics show three holes on each head of the HO, so I believe I'm good to go in that respect.
JamesC
Old Mar 10, 2008 | 05:41 AM
JamesC's Avatar
Crap. The water pump in the kit won't fit my application (no heater hose connection).
JamesC
Old Mar 10, 2008 | 09:22 AM
trumps2000's Avatar
Car: 1985 Z28
I think I had to buy one for a '88 truck application.
Old Mar 10, 2008 | 09:56 AM
JamesC's Avatar
That's what I discovered on another thread.
JamesC
Old Mar 10, 2008 | 01:45 PM
JamesC's Avatar
Was there any interference between the heater hose and the serp belt?
JamesC
Old Mar 10, 2008 | 05:00 PM
trumps2000's Avatar
Car: 1985 Z28
I haven't completely assembled it yet. I've only done a few test fits, so I'm not sure if its an issue yet.
Old Mar 10, 2008 | 05:46 PM
JamesC's Avatar
When the time comes, I'd very much like to know (apparently, you're the test mule in this set-up )
JamesC
Old Mar 10, 2008 | 08:24 PM
trumps2000's Avatar
Car: 1985 Z28
Haha no problem, won't really get to for at least 3 weeks though. Thats when I can park my car in front of my apartment again, street laws I also have to finish rebuilding my alternator and buy serp blades for my clutch fan. Think there is any problem with spinning the clutch backwards?
Old Mar 10, 2008 | 11:20 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
I'm currently running the GM "Deluxe" conversion on my 84 TA. I don't recall having a problem with the water outlet at the wp. One problem i did have, was my block was decked so I had some clearance issues to work out.
Old Mar 13, 2008 | 10:44 AM
JamesC's Avatar
You wouldn't because (as I discovered this morning) the water pump from the kit has the threaded hole that I need. For those not using the kit, the GM p/n is 88894005 or from CarQuest AUT 10-444 (reman) or NWP 51-2180 (new).
JamesC
Old Mar 15, 2008 | 08:46 AM
JamesC's Avatar
Another question. Since the p/s pump is relocated in the serp system, can I use the hoses from my current set-up, or will I be obliged to replace?
JamesC
Old Mar 15, 2008 | 11:13 AM
trumps2000's Avatar
Car: 1985 Z28
Well I don't know for sure, but I don't think its relocated much if any. Depending on the bracing behind it you should be able to reuse your lines. The setup I pulled off of '90 Jimmy 4.3L has a stamped brace for the alt and p/s which will interfere with the lines. The TPI and TBI setups use a bar to brace the alt. I haven't seen any factory bracing for the p/s. So there shouldn't be an issue there. I haven't test fit my p/s yet, cuz its a bit of a hassle, but I plan on using my Vbelt pump and so don't plan on disconnecting lines.
Old Mar 15, 2008 | 03:26 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
I did not have any problems using the stock ps hoses
Old Mar 15, 2008 | 04:35 PM
JamesC's Avatar
Many thanks for the reply!
JamesC
Old Jun 14, 2008 | 06:08 PM
trumps2000's Avatar
Car: 1985 Z28
Hey James, How did your install go? I'm almost done with mine, but I can't get the A/C brace to fit, the TES headers. How did yours go in, got any pics? The system is out of a 92 RS, but I believe its identical to your kit.
Old Jun 14, 2008 | 06:29 PM
JamesC's Avatar
Hey, trumps,
Sounds like you need a spacer. Here's my write-up (and some pics):
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Old Jun 14, 2008 | 09:05 PM
trumps2000's Avatar
Car: 1985 Z28
The problem is that the #2 exhaust tube comes up and over the #4 and #6 tubes, so it intereferes with the brace.
Looks like Edelbrock already knows this, I just have to bend the ends of the brace.
http://static.summitracing.com/globa.../edl-68753.pdf
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
LittleFranks
Oct 7, 2015 11:26 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
