i just installe slp runners when i start carrevs all the way up
Old Mar 9, 2008 | 04:07 PM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
Engine: 350 zz4, 305 tbi :(
i just installed slp runners when i start car revs all the way up
ok i just installed some slp runners when i started my car up it reves all the way up its crazy i have to shut it off before i blow n e thing what the heck did i do wrong?
Old Mar 9, 2008 | 04:18 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: i just installe slp runners when i start carrevs all the way up
throttle stuck open? check the cable next to your runners and make sure its not hung up in a bad position cause thatll effect it. make sure its run in the factory route.
Old Mar 9, 2008 | 04:29 PM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
its not stuck open the cables do feel loose
Old Mar 9, 2008 | 06:02 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
check all the intake gaskets and make sure bolts are tight!
Old Mar 9, 2008 | 06:42 PM
W72's Avatar
W72
Car: 89 GTA & 92 T/A covertible
Engine: 408LS-SC, 355 TPI
Transmission: 4L80e, 700r4
Axle/Gears: 12 bolt, 9 bolt
Maybe the IAC and ECM needs to relearn the idle from being disconnected?
Old Mar 9, 2008 | 06:49 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
make sure all the bigger vacuum lines are on, like brake booster ect.
Old Mar 9, 2008 | 11:40 PM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
do i have to switch to bigger lines?
Old Mar 9, 2008 | 11:49 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
you dont need bigger lines, just look for ones you may have broke of left off and double check the gaskets you installed on the runners
Old Mar 10, 2008 | 01:28 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
did you install this on the 91 Z28 thats in your profile? if so, did you get the later style runners? if you installed the pre-89 style you need to put a freeze plug in the little tube on the drivers side runner. i learned that the hard way some years ago.
Old Mar 10, 2008 | 01:30 AM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
has anyone had this problem b 4 how did you fix it?
Old Mar 10, 2008 | 06:58 AM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
how do i tell if they are the later style runners or not? yes i installed them on the 91 z28
Frozer!!!
Jan 19, 2024 04:55 PM
tazs2000
Jul 15, 2017 08:44 AM
Caspar
Jun 19, 2016 11:19 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
drathaar907
Aug 6, 2015 04:20 PM
