Angel valve job
Car: 89 irocz
Axle/Gears: 373
Angel valve job
what is a angel valve job? i was talking to some one and they told me to get a 3 angle valve job what exactaly is that and is it worth doing ?
Re: Angel valve job
"Angel" = heavenly beings that fly around with wings and play harps
"Angle" = the geometric feature where 2 lines or planes meet
I think you mean "angle"?
See this thread for some pics.
https://www.thirdgen.org/forums/tech...lve-seals.html
Note in the pics of the valves, that there is only ONE angle; the 45° one that touches the head casting. Imagine that there was another angle on each side of that surface, such that the 45° had a little more "blend" to the back of the valve and to the margin.
Note in the pics of the heads, that they show all 3 angles.
3 angles = factory (the minimum acceptable IMO)
1 angle = typical valves right straight out of the box (as those are), and cheap "rebuilder" regrinds
5 angle = a relatively performance oriented job, designed to allow max flow around the valve at low lifts, due to a smoother radius with no flow-disrupting sharp edges
"Serdi" = a mfr that makes a cutter that cuts a continuous radius in the head; as if, an "infinite # of angles" valve job (there are others, that's just the most common one you see talked about by name)
