Rocker Arm Stud Length
I want to install screw in rocker studs, but I do not want to have to machine the heads for guideplates because I already have self aligning rockers. How do I determine what length stud to use? Thanks!
Would these work?
Would these work?
Re: Rocker Arm Stud Length
It'd be much wiser to properly machine the heads anyway rather than half-a$$ing it, since they have to have some machine work anyway, and just put washers under the studs.
THat way, in the future if you ever DO need to install guide plates for whatever reason, they're ready; and you won't have to take them off and do it over.
Sonix, thank you! The only question I have is how would I install them? There isn't a way to tighten them like other studs I have seen...or are my eyes deceiving me?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You put two 3/8NF nuts on it and jam them together. Or grab it on the smooth shank and use a pipe wrench.
Use sealant or red loctite to hold it in place.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
I didn't think about double nutting it... good call
