did a burn out now i have no brakes
Old Mar 16, 2008 | 01:49 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
well i did a little smoke show and after i finished it my brake light came on and now my brake pedal travel to the floor. i let the car sit for alittle came out and the mater cyl was very low . I added fluild and pumped the brake pedal. the pedal came back up but the brake light still on and it does not stop like it used to.
Old Mar 16, 2008 | 01:53 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: did a burn out now i have no brakes
you may have blown a brake cylinder in the rear. pull the drums off both sides in the rear and check for heavy concentrations of brake fluid.
Old Mar 16, 2008 | 02:00 PM
Car: 91 formula
its 4 wheel disc. i will take a look.
Old Mar 16, 2008 | 02:12 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
hmm maybe you popped a rotted brake line or your master cylinder couldve given out.
Old Mar 16, 2008 | 02:20 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Most likely you blew a line. probably a front brake line since they do the most braking.
Old Mar 16, 2008 | 03:58 PM
Engine: Vortec 357
....or he could of blown his brake booster causing him to have no pressure. But yes a blown line could also be another factor. I'd start by tearing apart your front brake calipers..
Old Mar 16, 2008 | 04:07 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
if he blew a brake booster he would have a really hard brake pedal, just think what hapened when you block off the vacuum line for the booster.the pedal becomes hard.........if the booster is not holding vacuum the pedal will get harder. it is possible he blew a brake line or a brake hose.
Old Mar 16, 2008 | 04:42 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
when I blew my booster the pedal went down further than it did previously....pump your brakes up with the car off if it gets rock hard and doesnt go to the floor its prob your booster...if you find fluid on the ground ...well...
Old Mar 16, 2008 | 05:14 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Even if the brake booster fails, you still have brakes. A brake booster is just that a vacuum booster that assist in braking effort. Why would you start by tearing the front calipers apart? If it was a faulty caliper, the piston would probably be out of the bore and holding the rotor, from when he was doing a burnout.
Old Mar 16, 2008 | 05:46 PM
ljnowell's Avatar
Thats not even close. If you pump up the booster with the car off, the pedal should get hard and not go to the floor. it in fact should not go down until the car is started, and vacuum is applied to the diaphragm inside of it. I think the speculation is a moot point because the OP said that he was losing brake fluid and the light came on. This means that the pressure differentail switch has turned on the light due to a lack of hydrolic pressure in one of the circuits. FInd your leak, and you found your brake light problem.
Old Mar 16, 2008 | 06:53 PM
Car: 91 formula
well I blew a brake line. its pooring out from the back next to the rear shocks. I think they make this puddy clay that you can plug the line. i saw it somewhere. but i will need a new line.
Old Mar 16, 2008 | 07:19 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Putty clay? No way!! You definately need to replace your line, don't even mess around with a bandaid fix for your brakes!
Old Mar 16, 2008 | 08:09 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Brake lines endure 1800 - 2000 psi every time you push the brakes and around 2200 - 2500 psi in a panic stop, i wouldnt trust my car and my life to puddy when brake line is so cheap to buy. F.Y.I dont get any brake fluid on your paint, it will eat through the paint in about 30 mins.
Old Mar 16, 2008 | 09:41 PM
ljnowell's Avatar
I know thats what a lot of the books say, in reality though, the pressure inside the line really isnt that high, unless in a panic stop. Now, the pressure exerted by the force of the fluid against the piston is another story.
I wouldnt try a putty though, thats crazy. I know a lot of guys that use compression fittings, thats nearly suicide.
Old Mar 16, 2008 | 10:01 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
I was just trying to remember what my college said they were. Im sure the piston pressure is pretty high.
Old Mar 16, 2008 | 10:21 PM
ljnowell's Avatar
Thats what I mean, in automotive school (I went there too, thats partly how I became the friendly neighborhood ASE master tech) they taught us that too. I can tell you though, from doing balance tests on brake systems with pressure gauges installed where the bleeders go, they dont usually get that high. In a panic stop it is certainly possible though. The highest pressure is what is exerted on the piston(s) in the caliper or wheel cylinder.
Old Mar 16, 2008 | 10:52 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
thats what I said ..
Old Mar 17, 2008 | 05:50 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Get a line lock.. if you're gonna do a burnout, do it the right way.. plus, line locks are great for hills..
dbrochard
Sep 19, 2015 08:13 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
