Distributor Wiring
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Distributor Wiring
I have a harness from an 88 TPI (smaller distributor) and I put it onto an 86 TPI (bigger HEI distributor). My question is what do I need to modify on the 88 harness to make it work with the older HEI distributor?
Re: Distributor Wiring
Nothing.
Just cut the connector that's there off, and put slide terminals on the 2 wires and hook them up. The cap is even labelled to tell you where they go.
