checking the timing
Old Mar 19, 2008 | 11:41 AM
whatdayasay's Avatar
checking the timing
I replaced my dizzy o-ring and reinstalled it in the same location. How do i check my timing? it's a 1990 3.1L EFI RS.
Old Mar 19, 2008 | 08:42 PM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
Re: checking the timing
Buy or borrow a Timing Light ~40$.
Old Mar 19, 2008 | 09:01 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Also, you need to unplug the ECM timing advance wire, to get accurate timing at idle. It's a one-wire plug, tan wire if I remember correctly, and it should be sticking out of the wire harness near the A/C blower box. This will keep the ECM from adjusting timing, similar to unplugging the vacuum advance on an old school distributor.
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
