i have a 89 z28 ans it wont s start when it cold..
Old Mar 24, 2008 | 08:12 AM
camaro_tim81's Avatar
Car: z28
Engine: 402 Big Block
Transmission: th350
i have a 89 z28 it wont start when its cold out side but it will run fine when its warm out side its got a new maf ,ing coil ,cap , spaurk plugs, rotor , wire , tps, pvc . its a 350 tpi 5.7 when i go and try to start it when cold out side it is hard to start it will for a few but will die it just wont stay running but when warm out side it will start fine a and run fine.. plz help thank you
Old Mar 30, 2008 | 11:21 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: i have a 89 z28 ans it wont s start when it cold..
Go to Autozone and rent/borrow (it's free after they give your deposit back) a fuel pressure gauge and check the pressure and post back what it is.
Low fuel pressure fits the symptoms in your other posts too.
If you haven't changed the fuel filter, it back by the left rear tire.
Even if you convert it to carb you're still going to have to fix this.
Old Mar 30, 2008 | 03:26 PM
bigbrother's Avatar
Car: 89 formula 350
Engine: tree fiddy
Axle/Gears: Borg warner 9 bolt with 3.27s
Coolant Temp Sensor
IAC are the first 2 things that come to mind.
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
IROCZ1989
Jan 24, 2016 03:55 PM
Bryan F
Aug 18, 2015 02:28 PM
