help with engine build
Old Mar 24, 2008 | 12:03 PM
davep_96's Avatar
Car: 1987 Trans Am GTA
Engine: 355
Transmission: TH-700r4
Have some questions about my build. My 87 TA had a 4bbl 305 and im replacing it with a TBI 350. The engine is from an 89 chevy truck. I plan to get headers, delete emissions(AIR, cat etc), get new cam, and maybe new intake. Also, i have an auto trans and im going to buy a rebuild kit. So here are my questions
(keep in mind that i dont care about being street legal or passing emissions)
1 What cam should i get? The heads are stock on the 350, and i want to use the car for daily driving and street racing. i dont care about gas milage, i just want to beat up on some mustangs on a fri/sat night. What would be the best cam to get to achieve good acceleration? since i want to street race, top speed isnt really important. the whole lift and duration kind of confuses me, and i heard you need to take into consideration comp ratio but i dont know it. i just want a cam setup that will give me a lot of power but can be used on the street
2. what would be the best headers to get to give me a good hp gain? im looking to spend around 200-300 bucks.
3 should i keep the TBI or go to a nice 4 barrel setup? Our original plan was to go with a carb and get rid of the computer and emissions crap leaving just a motor, but would i get more power with the TBI or with the carb? again i dont care about gas milage just horses.
the whole plan for the car is to get some decent power on a budget. i have enough to get things like headers, rebuild kit, cam, etc but i dont want to go crazy. with your suggestions what kind of hp can i expect? sorry its so long but i dont want to build a bad combo and have a weak engine. thanks in advance
Old Mar 24, 2008 | 02:43 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: help with engine build
Lose the TBI If you are going to change the cam. The truck engine has hydraulic flat tabet cam in it but is set up for a hydraulic roller cam. you will gain a little power with roller but it will cost a little more. For a flat tappet I would run a Xtreme Energy XE268H Hydraulic Flat Tappet from comp cams. I have several friends that run this cam and love it. For a roller I would run a Xtreme Energy XR282HR Hydraulic Roller Camshaft.
Old Mar 24, 2008 | 03:48 PM
davep_96's Avatar
Engine: 355
thanks. if i use the Xtreme energy Flat tappet, will the stock lifters/valve springs/timing chain and gears work or do I need to upgrade those as well.
Also, what is a good carb to go with?And what size?
Old Mar 24, 2008 | 05:20 PM
Engine: 355
You should always use new flat tappet lifters on a new cam shaft. I would upgrade the valve springs also. With this cam Z28 springs will be fine and save you some money. Qjet is my choice.
Old Mar 24, 2008 | 05:41 PM
davep_96's Avatar
Engine: 355
what do you mean by z28 springs? stock z28 or aftermarket?
Old Mar 24, 2008 | 05:49 PM
Engine: 355
Welcome to ENGINEKITS.COMŽ. Tell your friends!
Product Details
RV-1943X
Elgin
Small Block Chevy +.100 High Performance Springs
$44.80 Set (16)
3 LB
Need to double check with comp but these should work I have used them for years.
Product Description
Specifications:
• Spring Type - Single w/Damper
• Outside Diameter - 1.250"
• Max Lift - .550"
• Nominal Load for Checking -
125lbs. @ 1.750"; 325lbs. @ 1.200"
• Coil Bind - 1.16"
I don't know for sure but I have been told they are stock replacment for the 1970 LT1.
Last edited by BASSETT IROC 85; Mar 24, 2008 at 05:52 PM. Reason: Automerged Doublepost
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
