Will not Idle at start up and dies, need help
Old Mar 25, 2008 | 09:10 PM
supermankbk's Avatar
Ok so here is the deal, I have an 86 2.8L V FI Camaro. In order to start it I have to give it gas and then it just dies after I take my foot off. It does not matter if the engine is warm or cold. after i drive it for 1/2 a mile it will idle. but before the 1/2 mile it will die every time i have to stop. I replaced a broken vacuum line but it did not change anything. I changed my fuel filter and that too has done nothing. Occasionally when driving it will cut out and be unresponsive to to the gas pedal, even when pumped. Is this a fuel pump problem? Timing problem? clogged injectors? bad throttle positioning sensor? It looks like the previous owner has tampered with the throttle sensor. Any advice would be appreciated. Thanks
Old Mar 25, 2008 | 09:37 PM
RicksIroc86's Avatar
Car: 84 camaro z28
Re: Will not Idle at start up and dies, need help
idk if its the problem but id replace the cap and rotor and possibly coil, thats what im doing on mine
Old Mar 27, 2008 | 10:11 AM
well what exactly is wrong with yours? If it was my distributor wouldn't it have a rough idle all of the time? Or is my computer compensating for the bad spark after I drive it for a bit?
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Wade787b
Sep 29, 2015 01:15 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
perZ
Aug 15, 2015 01:17 PM
