Pick Your Brain... Car Not Firing
Old Mar 26, 2008 | 02:54 PM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
'91 Z28 L98 Built. Bought the car nearly three weeks ago and it ran like a champ, not a single flaw except needing some more fine-tuning(car runs rich), but had zero mechanical issues.
Week and'a half ago, I developed a knock and my check engine light starting going off... turned out I lost one of the bolts to my smog pump pulley and it was wobbling. So, I did a smog pulley delete and ran a new belt... solved the knock.
After nearly another week, car was back-firing, loading up, etc. I pulled the plugs and they were fouled, so I put in new plugs. Car ran fine again with little hint of loading up. The loading up bothered me, so I cheated and pulled the plugs and cleaned them(had bit of gas on'em) and wah-lah.
Two days ago the car started missing and I brought it home. Hadn't touched it till last night when I pulled a plug and noticed it was still a little foul. Well, now the car won't even fire... just cranks. It started twice, idled rough and died. This morning, I swapped all the plugs again(had maybe 10 miles on last ones), replaced the distributor cap and the roto bug. Same problem, car acts like it's not getting a spark, just cranks all day.
Old Mar 26, 2008 | 05:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Coil and/or ignition control module. One going bad often takes out the other.
Another possibility, the pick-up coil has gone bad. An even more rare reported failure is the distributor trigger wheel going bad in one way or another.
Old Mar 26, 2008 | 08:56 PM
Cam-aro's Avatar
Car: '91 Z28
Re: Pick Your Brain... Car Not Firing
This is what someone else says. Car has MSD... we're afraid it's the Blaster Pak that went bad. Luckily, a buddy has an extra so we're test it all then plug his in and see what happens.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
camaro71633
Sep 1, 2015 10:24 AM
TheExaminer
Aug 26, 2015 04:59 PM
apie2546
Aug 10, 2015 05:43 PM
djmarch
Aug 9, 2015 05:27 PM
