Ignition Coil/EGR solenoid Mounting?
Old Mar 27, 2008 | 03:00 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Can someone show me a picture that shows how the ignition coil and the egr solenoid mount to a 305 Tuned Port Injection motor? Thanks
Old Mar 27, 2008 | 05:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
An '85 would have the coil in the distributor cap from the factory.
Have you asked on the TPI forum?
Old Mar 27, 2008 | 06:01 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Ignition Coil/EGR solenoid Mounting?
I tried the TPI forum but didnt get an answer yet. Yes 85 would have the coil in the cap but the harness and distributor are from a 1988.
Old Mar 29, 2008 | 07:23 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
anyone
Old Mar 30, 2008 | 05:05 PM
Pat Hall's Avatar
I don't have a picture handy at the moment, but there's been pics posted on here before, probably in the tpi forum. Anyways, there's a bracket that both the coil and egr solenoid attach to. The bracket attaches to the last 2 intake manifold bolts on the passenger side, back by the distributor. Tpiparts.net has a pic of the bracket I'm referring to. The egr solenoid attaches to the underside of it, and the coil mounts to the top side of it. If you type "engine pics" into the search bar, and specify tpi forum only, you should be able to find some pics that show it. Nevermind, I see you managed to get a pic in the tpi forum. Anyways, if you do need that bracket, you can get it from tpiparts.net.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
