1.6 roller rocker installation
Old Mar 29, 2008 | 09:17 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
will the jegs 1.6 aluminum roller rockers i am installing require i put on tall valve covers? its an L98 centerbolt in an 88 gta
thanks,
Jason
Old Mar 29, 2008 | 09:25 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
Re: 1.6 roller rocker installation
they wont fit under stock valve covers...need tall covers or a spacer plate for stock ones.
Old Mar 30, 2008 | 12:28 AM
thunder85's Avatar
Engine: 5.7L w/hsr
ah... i though that would be the case. thanks
Old Mar 30, 2008 | 06:13 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
did you get self aligning rockers?
Old Mar 30, 2008 | 09:24 AM
thunder85's Avatar
Engine: 5.7L w/hsr
sure did.. anywhere u know of sell tall covers cheap? looks don't matter, just function.
Old Mar 30, 2008 | 02:40 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Is there a set of 1.6 rockers that are self aligning that will fit under the stock covers?
Old Mar 30, 2008 | 05:16 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
I believe all of the "narrow" 1.6 ratio on a 3/8 stud, will fit under a stock valve cover, Or you can go with the, roller tip rockers, in a 1.6 ratio, and they will fit, plus they are affordable.
Old Mar 30, 2008 | 07:08 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Alright well I am clueless as to which ones to choose. ANy ones better than the other. I have been searching on here and everyone has their opinion. I just want em to fit under the valve cover, be 1.6 ratio and its for a roller cam.
Old Mar 30, 2008 | 08:50 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
I went with the chrome moly roller tip rockers, because they are stronger than the aluminum roller rockers, I have seen the aluminum ones break in half. Let alone, the narrow ones you have to use for these valvecovers, plus they are less than half the price.
Old Mar 30, 2008 | 10:15 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
hmm okay. ill have to find me some.
Old Mar 30, 2008 | 11:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
comp cams magnum rockers fit. I ran them on my stock covers just fine. part # 1418-16. 172 bucks shipped on ebay
1.6 ratio but they are steel not aluminum. not a bad thing, as steel is stronger and less prone to fatigue failure.
the pro magnums i've heard hit on the stock covers tho
Old Mar 31, 2008 | 12:34 AM
thunder85's Avatar
Engine: 5.7L w/hsr
well thats fantastic news... i just spend 225 on a set of aluminum roller rockers and they are the inferior and more expensive choice? how many miles can i expect to get out of them before i need to start watching for one letting loose?
Old Mar 31, 2008 | 12:43 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I believe they are talking higher rpm power handling. You will be fine as long as you dont consistently beat it down with lots of power
Old Mar 31, 2008 | 09:16 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
under heavy tension from big powerful valve springs will definately beat on a aluminum rocker, but i'm not sure how long it would take before i'd get worried about running them. For most setups you will be fine for awhile. They definately are not your 100K mile setups or the factory would use them, but they definately are not a 5-10K mile running piece either.
Other than that, i think you will be fine for awhile. after 10-20K miles i'll take a look at them to see how they are. maybe every 10 K miles, pop the cover off and take a peek. You may need to search on the topic, because i'm not sure how well they hold up in street motors, i'm just goin by what i've heard/read in a few places. ITs definately a possibility but not an immediate one
midge54
Dec 27, 2019 04:14 PM
Mickeyruder
Sep 2, 2015 02:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
