time my lg4
Old Apr 2, 2008 | 09:28 PM
RandyZ's Avatar
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
time my lg4
I am looking around for a tanish colored wire witha black line and i can't find one ???? i want to time this car and i cant find it ????? could someone shoot me pics ??????
Old Apr 2, 2008 | 09:40 PM
ljnowell's Avatar
Re: time my lg4
Look above the ac box, under the hood. you should find it there. Its a longish connector, like maybe 1.5 inches or so. single wire, black connector.
Old Apr 2, 2008 | 10:21 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: time my lg4
on the 83, you need to disconnect the 4 pin connector to the distributor. the earlier models don't have the single pin bypass
Old Apr 4, 2008 | 09:28 PM
RandyZ's Avatar
Re: time my lg4
with the 4 pin out how do you start the car i have the black wire on i believe , any pics
Old Apr 4, 2008 | 10:10 PM
ljnowell's Avatar
Re: time my lg4
whooops!
Old Apr 4, 2008 | 10:27 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Re: time my lg4
the 4 pin conn is the link between the ecm and the dizzy. the dizzy itself is still a normally powered hei set up. with it unplugged, it will operate normally, just without any timing advance or retard control. set dist. where it needs to be, plug 4 pin back in, reset check engine light, should be good to go.
RazorN8
Jan 7, 2022 11:44 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
