for anyone with AFR heads....
Old Apr 4, 2008 | 11:02 PM
thrilla135's Avatar
Car: 1987 trans am
Engine: 406
Transmission: th:400
Axle/Gears: 4:88
i just bought a set of afr heads...they are the 210 cc race ready heads..they feature 2.08 + .100 long valves and 65 cc chambers...i am .700 lift springs with i believe a 1.562 valve spring diameter...i am wondering if you were able to use standard rocker arms and the standard length pushrods...i have heard there should be concern with the pushrod lengths with the longer valve....and as far as the rocker goes ( its a fat 1.6 by the way) it seems like i have no clearance between the rocker and the valve spring...just wondering if anyone else has had this problem and knows any answers...thanks
ULTM8Z
Oct 2, 2015 01:25 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
355tpipickup
Sep 28, 2015 05:50 PM
tuningnewb
Sep 23, 2015 07:06 PM
355tpipickup
Sep 13, 2015 11:35 PM
