Replacing Cam
Old Apr 6, 2008 | 12:00 PM
Gregg85IROC's Avatar
Car: 1985 Camaro IROC-Z
Engine: 5.0L 305 V8
Replacing Cam
Hey,
Is it at all possible to swap out a camshaft on a carbed 305 without lifting the engine or anything like that, because I've got limited tools and knowledge and I'm only 16 so an engine lift really isn't in my price range.
Thanks in advance.
Old Apr 6, 2008 | 08:14 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: Replacing Cam
yes. Remove the front of the engine, the intake manifold and valve covers. Remove the radiator, and condensor and cooling fans. Remove the timing chain cover. You dont have to remove the oil pan, but once you get the timing cover off, there are tabs you have to cut to put it back on. It seems like alot of work, but its alot of 'easy' work.
Fronzizzle
Mar 18, 2019 08:29 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
