head cc
Old Apr 7, 2008 | 12:41 AM
Artic-Trans am's Avatar
Car: 87 TA
Engine: 350 modifyed Stelth Ram
Transmission: 350 rew lock up
Axle/Gears: 9"
head cc
Hi
I have demounted my engine to change the cam and head's.. but I do not find the cc on my old heads. I have check the listing I know on the net but the only info I see is what year they where prodused
well if anyone can help me the casting number is: 458642
Old Apr 7, 2008 | 02:39 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: head cc
A quick google search turned up this:
"these are 76cc chamber, small valve crack prone smogger heads that are lighter than the 882 units, they make good wheel chocks or boat anchors."
http://www.hotrodders.com/forum/sbc-...2-a-19256.html
Old Apr 7, 2008 | 07:59 AM
Car: 87 TA
Axle/Gears: 9"
Re: head cc
hi
Thanks.. I didn't do a google,,,
sometimes the easy is the best...
now, I just demounted the heads. Now have to find some info about tha pistons. Anyway to find the Piston Head Volume?
I did belive this was stamped in the piston.
The thing is that I plan on going to put on 64cc heads, but I have to be sure about the clearance and comp!
Just for information, I did not know the comp.ratio in this enginge before I took it apart.
this is a 2 bolt block-engine that was in a -83 trans am, but I think tis is not the original engine.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
