T5 bench test before purchase
Old Apr 7, 2008 | 04:23 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
hey guys as you may know I killed my t5 this week, although I have not pulled the tranny yet I found a great deal on another t5. The only problem is that the tranny is too cheep $100 so i want to bench test it i figure all i can do is put it through the gears and make sure the tail shaft turns. Will i need any tools or can I turn it by hand? what does it weigh? is there any way to tell if the syncros are good? what should I do to it before installing it?
Thanks for reading!
Old Apr 7, 2008 | 07:48 PM
mxcrazed's Avatar
Engine: None
Transmission: none
Re: T5 bench test before purchase
OOps misplaced this one bump/move please mods
I got the t5 tonight it seems to go into all the gears it leaked some fluid out the tail while carrying though I thought only 700's did that. Is the rear seal on the yoke or the tail shaft on the t5? the input shaft moved up and down a little is this acceptable I have a feeling not?
Old Apr 7, 2008 | 09:38 PM
z28freak84's Avatar
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
Sounds like a T5. Put it in and let er eat. ALL trannys will leak out the back if the driveshaft's not in. And the input will NOT be "play" free. It will have some play....Put it in.
Old Apr 7, 2008 | 10:05 PM
mxcrazed's Avatar
Engine: None
Transmission: none
Think I should open her up and clean out any sediment? how do you know that my input shaft isn't too loose? What do you mean " let er eat", you mean destroy it again lol.
I would like to open up the access panel and compare my syncros <--spelling?
the old t5 shifted beautifully will I be able to tell if the ones in the new tranny are equal condition without disassembly?
Hotrodboba400
Dec 10, 2019 07:07 PM
BumpaD82
Feb 26, 2016 02:57 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
punkmaster98
Sep 30, 2015 11:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
