Can't get nut on Starter off, help?
Old Apr 8, 2008 | 02:50 PM
ChrisPcamaro's Avatar
I have a 92 rs with a 305, and one of the nuts that holds on an electrical connection to the starter won't come off. It turns, but so do the threads that it's on. I'm not positive(I can barely see the nut, let alone the connector that it's holding onto the starter), but I think it''s running to the battery, and there may be another wire attatched to it. Ironically, if I had the starter out, I'd know which wire it was.
I have almost no room to work with it, so short of cutting the connection off, is there anything I can do to get the wire off the starter?
Old Apr 8, 2008 | 07:00 PM
Damon's Avatar
Re: Can't get nut on Starter off, help?
I believe there's another nut on the other side of the connection (can't remember) which you might be able to get a slimline wrench on to give yourself something to torque against as you try to turn the outer nut to get the wire off.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
gord327
Sep 29, 2015 10:18 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
3.8TransAM
Sep 27, 2015 08:37 PM
