elgin e1090p
Old Apr 9, 2008 | 11:38 AM
bigzeke's Avatar
elgin e1090p
hey guys anyone ever run the elgin e1090p solid cam ,ive heard of guys having problems with this cam and im getting ready to start engine with this .just looking for general info thanks /355 cid big zeke
Old Apr 9, 2008 | 07:28 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: elgin e1090p
What kind of "problems" are you expecting?
If your using dual coil racing valve springs, Remove the inner coil for cam break in. If you use a single stock diameter spring watch for coil bind at full lift.
Did you degree it in? Lock out the spark timing curve (34-36deg at idle full time. 3.5" power valve. needs a 3500+++stall converter and 4.10-4.56 gear.
I used this cam in a 12.65:1 350 with ported big valved shaved 305 heads and a holley strip dominator intake. A beast.
V to P clearance can be tight if both the block and heads have been shaved a lot.
Old Apr 10, 2008 | 09:45 AM
bigzeke's Avatar
Re: elgin e1090p
not really expecting any problems just read that some cat used this and had problems right off so i thought to myself that maybe his lash was set too tight or too much spring pressure however im running a fresh set of dhumps 2.02 valves kb flat tops 3800 convertor and 4.10 rear performer rpm intake roller rockers ,really built this engine on the cheap ,in the process of building big motor all roller ,motown 23 degree heads j&e pistons ,but just was curious about this stick ,thanks for your input and i hope its a beast for me what kind of trap speeds did you see with the 4.10 and what kind of car did you have it in ,mine is a 92 firebird will post pics in about a week,does this cam have decent low end torque -------------------------------big zeke 355 bird
Old Apr 10, 2008 | 01:10 PM
F-BIRD'88's Avatar
Re: elgin e1090p
What valve springs do you have? If you're using a stock diameter spring you'd be better off with Elgin#1091P. Its the same except .504" gross lift
Either can easily use a 4.56:1 gear. The engine really wants to rev.
I never did get a MPH on it. Other issues. Made lots of power.
With a dual plane an 4.10's I'd cam it a little differently thou.
Isky#201534 http://www.iskycams.com/timingchart....g_chart_id=180
Old Apr 10, 2008 | 02:07 PM
bigzeke's Avatar
Re: elgin e1090p
springs are stock gm pieces i had them shimmed at the machine shop hopefully ill be happy with this set up ,i did check for coil bind and everything seems to be in order will know saturday morning starting it up but man thanks for all the info ill let you know how it does
Bubbajones_ya
Jul 6, 2024 08:32 PM
bigzeke
Jul 2, 2021 07:18 PM
skinny z
Oct 5, 2015 06:23 PM
bigzeke
Nov 30, 2009 12:58 PM
bigzeke
May 12, 2008 02:23 PM
