weird fuel issue
Old Apr 11, 2008 | 11:52 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
weird fuel issue
i have a 89 iroc 350 tpi to carb swap mallory regulator so it only puts out 6psi. Well for the last two months once a month my car will just start idling low then eventually die i pump the hood and check my fuel pressure gauge it reads 0 usually it holds 6 for quite awile. i start the car and it stay at 0 and runs like **** until the fuel bowls in the carb go dry i let it sit for a min fuel pump primes then runs fine. would a dying fuel pump only do this once a month? It feels like its just as powerful before i had fuel issues so its holding pressure good only once awile it will do this.
Old Apr 14, 2008 | 01:08 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: weird fuel issue
Fuel leaks, or the fuel pump mounted to high. I had both on my TBI to carb swap. I also had to remove the in tank pump, and make a pick-up for it. I hope this at least is a good starting point.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Cleotiz
Jan 6, 2018 08:56 PM
EFR2000
Aug 18, 2015 08:54 PM
