82 T/A Engine Died after 3 sec. Electrical Prob?
Old Apr 14, 2008 | 10:01 AM
Black_T_Top's Avatar
Car: 1982 Pontiac Firebird Trans Am
Engine: 4BBL 305 V8
Transmission: 200 4R
I have a stock 1982 Trans Am with the 4BBL 305 engine and only 14,600 miles. This morning when I started the car, it started with ease, ran for 3 seconds and then died. Then it would not run. The engine cranks and cranks, but it will not fire. Yesterday the car ran fine. I started and stopped at least 5 times with no problems. Last weekend I had the same problem and took off the battery cables and cleaned all of the connections. Then after I put everything back together, it started fine. I’m thinking this may be a grounding or electrical problem, as my water temp gauge is pegged past the hot. Yesterday while driving, it came back to normal for a few minutes but then pegged again.
One more piece of info: Last weekend I drained the battery trying to get the car started. When I hooked up the battery charger, it would not take a charge. Yet, when I switched the battery into my other ’82 Trans Am, it took a charge just fine. Any ideas what electrical connections I should begin checking? I don’t have a clue where to begin.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
