Push rods
Old Apr 14, 2008 | 03:17 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
Push rods
is there any way i can find out the length of the pushrods i need with out buying a adjusabel one Becasue im just using vortec heads on a 350 with 1.5 roller rockers.
Old Apr 14, 2008 | 03:41 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: Push rods
Stock pusrods should be the right length. It should be 7.2" if you have a stock roller, or 7.8" for a flat tappet. When assembled the center of the roller tip should be just barely past the center of the pushrod. Just don't forget to use guide plates and hardened pushrods. I made the mistake of using regular pushrods with plates, they don't last long.
Old Apr 14, 2008 | 05:24 PM
ljnowell's Avatar
Re: Push rods
The roller tip should actually be just a little past halfway of the valve tip. And you need to checke the sweeping pattern of it also. Stock ones will probably work, but will not be neccesarily right. I would mock up with the stockers and see what you need.
Old Apr 14, 2008 | 06:00 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
Re: Push rods
what diamiter do i use 3/8'' or 5/16'' ?
Old Apr 14, 2008 | 06:37 PM
Bigseth's Avatar
Car: 86 Iroc 383 carb, 97 T/A WS6
Re: Push rods
5/16, you can get those hardened pushrods from comp for like $30
Seth
Old Apr 15, 2008 | 12:59 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Push rods
I just bought a pushrod length checker, it cost me a grand total of $12 here in canada, and was on the shelf ready to go. I highly recommend you do the same.
I ended up getting 7.870" Ford 351C pushrods for my 350. Who would have thought right?
Old Apr 17, 2008 | 11:04 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
Re: Push rods
ya i guess ill pick one of thoes up
Old Apr 18, 2008 | 12:02 AM
EvilCartman's Avatar
Car: '82 Z28
Re: Push rods
Also, buy 1 piece pushrods. I didn't know any better and broke the tips off of 2 pushrods at the track 2 different times out
RS Reaper
Oct 17, 2018 07:52 PM
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
