305 tpi w/113 heads...can i unplug egr and block it?
Old Apr 15, 2008 | 08:32 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Hey everyone, Ive got a 87 305 tpi thats bone stock... Ive got a set of 113 heads, comp cams 258, oval headers (Im going to try and use) with no o2 bung.. My question is if I put a bung on the ypipe for my 02 sensor and basically unplug and block my egr port will I have any probs with my stock ecu or performance? thanks everyone
Old Apr 15, 2008 | 01:49 PM
Guest
Guest
Posts: n/a
Re: 305 tpi w/113 heads...can i unplug egr and block it?
It should be ok. I havent had a MAF car set a code for EGR yet, or have any performance issues.
You might consider porting those heads before you put them on, as cast they arent a whole lot better than a factory cast iron head.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
