CHARCOAL CANISTER
Old Apr 17, 2008 | 04:12 PM
wano1147's Avatar
CHARCOAL CANISTER
I have a 1988 formula that was originally a TBI car. I have converted it to MPI on a 383 SBC. My question is, can anyone explaine how the charcoal canister system works? i.e. when the computer activates it, why it's there in the first place, do I really need it. I am thinking I could increase engine vac without it. This car is not a daily driver although it could be, cam lift is .510 int. and .520 ex
I would appreciate any input.
Old Apr 17, 2008 | 05:24 PM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Re: CHARCOAL CANISTER
From my Chiltons:
Evaporative Emission Control (EEC) Systems
The Evaporative Emission (EVAP) control system used on all vehicles is the charcoal canister storage method. This method transfers fuel vapor from the fuel tank to an activated carbon (charcoal) storage device (canister) to hold the vapors when the vehicle is not operating. When the engine is running, the fuel vapor is purged from the carbon element by intake air flow and consumed in the normal combustion process.
Removal of the vapors from the canister is accomplished by a solenoid operated bowl vent or vacuum operated purge valve mounted on the canister. In addition to the fuel system vents and canister, the fuel tank requires a non-vented gas cap. The domed fuel tank positions a vent high enough above the fuel to keep the vent pipe in the vapor at all times. The single vent pipe is routed directly to the canister.
These systems commonly use an in-line EVAP pressure control valve as a pressure relief valve. When vapor pressure in the tank exceeds approximately 0.7 psi, the diaphragm valve opens, allowing vapors to vent to the canister. Once the in tank pressure drops below 0.7 psi, the valve closes causing vapors to be help in the tank.
If the EVAP system is not functioning properly, any one of the following conditions may be as result:
  1. Poor idle, stalling, and poor driveability can be caused by:
    • Inoperative purge solenoid valve
    • Damaged canister
    • Hoses split, cracked or not connected to the proper tubes
  2. Evidence of fuel loss or fuel vapor odor can be caused by:
    • Liquid fuel leaking from the fuel lines
    • Cracked or damaged canister
    • Inoperative canister control valve
    • Disconnected, misrouted, kinked, deteriorated or damaged vapor hoses or control hoses.
If the solenoid valve is open, or is not receiving power, the canister can purge to the intake manifold at the incorrect time. This can allow extra fuel during warm-up, which can cause rough or unstable idle.
Operation
This system reduces the amount of gasoline vapors escaping into the atmosphere. Some models employ a purge control solenoid which is controlled by the ECM, to open and close the EEC system. Other models use a canister mounted vacuum purge valve; when the engine vacuum reaches a certain pressure, the valve opens allowing the gas vapors to be drawn off to the carburetor for burning.
Carbureted models use an exhaust tube from the float bowl to the charcoal canister; fuel injected models eliminate the fuel bowl tube (as no float bowl is used on fuel injection systems). Fuel vapors from the gas tank travel from the tank to the vapor canister, where they are collected. Although the system varies from vehicle-to-vehicle, the operations are basically the same.
Testing Tank Pressure Control Valve
  1. Using a hand-held vacuum pump, apply a vacuum of 15 in. Hg. (51 kPa) through the control vacuum signal tube to the purge valve diaphragm. If the diaphragm does not hold 5 in. Hg. at least for 10 seconds, the diaphragm is leaking. Replace the control valve.
  2. With the vacuum still applied to the control vacuum tube, attach a short piece of hose to the valve's tank tube side and blow into the hose. Air should pass through the valve. If it does not, replace the control valve.
Hope this helps you out a little bit.
Old Apr 17, 2008 | 05:30 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
The only downside to removing the canister is you will sometimes have a slight smell of gas fumes around the front of your car where the vent line is.
Old Apr 17, 2008 | 05:33 PM
wano1147's Avatar
Yes thanks, that is interesting.
Old Apr 17, 2008 | 06:35 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i remvoed mine and put a vented cap on also, i plugged the line comming out under the hood, and a plug on the evap port on the TBI, no issues with it removed, not better, not worse, removed it to put an air compressor in that area for the air horns......
Old Apr 18, 2008 | 09:24 AM
wano1147's Avatar
I would like to be able to use that space for a vacuum can, what if I eliminated the charcoal canister and ran the vent tube directly to the throttle body with a restrictor inside the tube? I am not concerned with vapor emissions, this car is not emission compliant anyway.
Old Apr 18, 2008 | 07:39 PM
89RS_82Z's Avatar
just plug both the port and the line off, then use a vented cap, i think if you do as you are taking you may have issues, not sure
Quzyle
Oct 15, 2015 03:35 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
TBRays98
Sep 6, 2015 05:05 PM
