Head stud issue
Old Apr 17, 2008 | 06:01 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
Transmission: Built 700R4 w/ 2500 stall
Axle/Gears: 3:73 posi
Head stud issue
Well i bought a set of 062 vortec heads off of a member of this board and was getting the machine work and whatnot done and when they were pulling the studs so i can run screw in ones, one of the guide bosses broke off so one head is trashed, which isnt anybody's fault i guess, just my poor luck. Im going to run the hotcam with bigger springs, should i keep the other head with pressed in studs and get another head to match? and run it like that.
Im leary of pressed in studs, but i dont wanna be f*cked out 600 bux. Anyone have opinions on running .525 lift with the pressed studs?
Thanks.
Old Apr 19, 2008 | 05:09 AM
Pat Hall's Avatar
Re: Head stud issue
I'd say the general rule of thumb is anything over .500 lift should really have screw-in studs. You might be ok with press-ins, but it's kind of a gamble. If you're really worried about another broken guide boss, you could always have them drill and pin the press-in studs. It's not as fancy as screw-ins, but it should do the job.
Old Apr 19, 2008 | 08:49 AM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
Re: Head stud issue
I thought of a new plan, i got another head for free, im gonna get it machined to match my other, sell those on ebay, then get a set of Dart iron eagle s/s's which seem to be just as good as the vortecs.
Old Apr 19, 2008 | 10:45 AM
Vader's Avatar
Re: Head stud issue
The factory Vortec and LT1/L99 heads used a sealant on the studs, since they penetrate the intake port runner roof. It's usually safest to heat the surrounding area before pulling the studs to prevent just such an occurrence.
I know it's a littler late for that head, but you might want to impart some of that information to your "machinist" or shop.
Old Apr 19, 2008 | 08:43 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Head stud issue
Yea, what he said. I think it is "someones" fault, but you'll never prove it.
Old Oct 7, 2010 | 11:09 AM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
Re: Head stud issue
fast forward a long time and ive been runing the vortecs with pressed in studs, and a 510 530 lift cam and all has been well untill last weekend, trans didnt shift right and i hit 7K and pulled out a rocker stud.
Found me some screw in studs finally, now i just need to find a tap and i should be good to go again. Def hooking the msd rev limiter back up!
italiano67
Dec 11, 2016 09:21 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
camaro71633
Sep 1, 2015 10:24 AM
355tpipickup
Aug 25, 2015 12:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
