stock roller lifters are good till?
Old Apr 18, 2008 | 10:59 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I pulled my lifters today to find out that they are in perfect condition. I was curious if they are in great condition, should i just use those and return the set i have? My motor build is pretty big. Im shooting around the 400hp n/a range and a 150+ shot of spray.
My compression ration is going to be 10.75:1
I need suggestions as quickly as possible. Thanks guys
Old Apr 18, 2008 | 11:14 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: stock roller lifters are good till?
Everyone will tell you that you can re-use roller lifters with a new cam.
If it were me building a 400 HP N/A 383, and then adding NOS to that, well... if the old lifters have much time on them, I'd install new ones.
Old Apr 18, 2008 | 12:35 PM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
I would go with the better safe than sorry route myself, but that is just me.
I did want to ask though, are you running this car on pump gas?
Old Apr 18, 2008 | 01:27 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Ya I already spent the money on them. Might as well sell the old ones. lol
I will be using 93 octane. I have aluminum heads and I will be fine as I have been told.
Old Apr 18, 2008 | 01:34 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ls7 lifters!
Old Apr 18, 2008 | 01:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Stock roller lifters & rev kit - know a couple of guys at the track spinning over 7k RPMs with them.
Old Apr 18, 2008 | 02:09 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
ls7 lifters
84z96L31vortec
Aug 20, 2017 12:16 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaro71633
Sep 1, 2015 10:24 AM
BrianI
Aug 9, 2015 11:52 AM
