Roller Rockers
Old Apr 19, 2008 | 02:00 PM
daghstdrummer's Avatar
Car: 1986 Z28 Camaro, 2002 Audi A4 (DD)
Engine: 350 .30 over w/bang for buck combo
Axle/Gears: stock for now
Roller Rockers
Which type of roller rockers would be most beneficial for my motor.. its a 350 bored out .30 over with stock heads and a cam with these specs..:
Cam/Lifter Kit Advertised Intake Duration: 282
Advertised Exhaust Duration: 282
Advertised Duration: 282 int./282 exh.
Intake Duration at 050 inch Lift: 224
Intake Valve Lift with Factory Rocker Arm Ratio: 0.465 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.465 in.
Exhaust Duration at 050 inch Lift: 224
Lobe Separation (degrees): 114
Duration at 050 inch Lift: 224 int./224 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.465 int./0.465 exh. lift
Old Apr 19, 2008 | 08:31 PM
squeeezer's Avatar
Car: 5 cars
Re: Roller Rockers
imo
if you are questioning the rockers then you are questioning your cam
Old Apr 19, 2008 | 10:19 PM
Re: Roller Rockers
i'm questioning which rockers would go best with the cam
Old Apr 19, 2008 | 10:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Roller Rockers
Whatever rockers you can afford. You don't have a lot of lift to need anything special.
That looks like some sort of power adder cam with the long duration and short lift.
Old Apr 19, 2008 | 10:56 PM
Re: Roller Rockers
yea i bought the cam w/ an intake and carb kit from summit... i just got another set of stock heads b/c mine were shot and i can't afford a set of aluminum ones that i want.. but i have some left over for the roller rockers... would a set of 1.6 rockers work ok?
Old Apr 20, 2008 | 12:39 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Roller Rockers
1.6 rockers would be pushing the limits of the stock springs. It's still under .500 lift but it's getting close.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
