Speedo And Odo Not Working!
Old Apr 21, 2008 | 01:45 PM
3rdGenWillie's Avatar
Car: 92 Lo3 RS
Engine: 305 roller tbi
Transmission: t-5
Axle/Gears: 3.08 open
1992 Tbi Rs T-5. Speedo and odo died. Cruise control works. Pulled Speedo unit but cant access gears to see if broken (made that way). It is electronic speedo. How to diagnios this? Can this stock unit be upgraded to higher mph w/ out ecm chip work? any help thanks.
Old Apr 21, 2008 | 09:26 PM
Car: 92 Lo3 RS
Transmission: t-5
Re: Speedo And Odo Not Working!
bump.....
Old Apr 22, 2008 | 01:14 PM
Car: 92 Lo3 RS
Transmission: t-5
anyone?
Old Apr 22, 2008 | 03:47 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
you might get a better response in the electronics forum.
The odo probably isn't working because the speedo isn't working. Since your cruise control still works than it most likely isn't the VSS it is more than likely the speedo itself, which means that you'll have to swap out the whole cluster(sucks) since it is all one unit.
I believe that you can swap out a cluster for 90-92 as long as it is v8-v8 or v6-v6, don't quote me on that I don't have any experience with the 90-92 clusters.
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
Wade787b
Sep 29, 2015 01:15 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
