Heads on a 305?
Old Apr 24, 2008 | 03:08 PM
white91's Avatar
Car: 91 CamaroRS convertible
Engine: 305 TBI
Axle/Gears: stock
Heads on a 305?
I have a 91 camaro with a Lo3. Is it possible to put heads with 2.02/1.60 valves on it or will they hit the cylinder walls? Any info would be appreciated.
sean
Old Apr 24, 2008 | 04:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
They won't hit the cylinder wall until very high lift, but they won't be of any performance benefit.
Old Apr 25, 2008 | 01:58 AM
white91's Avatar
Engine: 305 TBI
Axle/Gears: stock
Re: Heads on a 305?
thanks
Old Apr 25, 2008 | 11:55 AM
HotRodJackson's Avatar
Car: 1991 Pontiac Trans Am GTA
Transmission: 700 R4 slushbox
Axle/Gears: 2.73 Posi
Re: Heads on a 305?
Define high lift for me; what kinda numbers you talking, and how much does head gasket selection affect the choice? And does it actually hit the cylinder block, or is it more safety for stock pistons?
Old Apr 25, 2008 | 02:35 PM
five7kid's Avatar
Something in the .60" lift range. Head gaskets would only make a difference in the .025" or so with a thicker gasket giving you that much more before hitting the top of the block.
You could machine eyebrows in the block if you really wanted to go beyond that lift. They did it with BBC's.
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
